Generator with Goodwe ES
Hi All
Considering what can happen this winter.
How would one go about incorporating a small generator with the Goodwe ES inverter.
This inverter does not have a logical inverter input from what I understand or can identify.
Thanks in advance for your advice
Danie
21 hours ago, Beyma said:
Hi Danie,
I've read somewhere in on the GoodWe site the ES doesn't support generators and should not be connected to one.
Yes I know. Therefore the post.
I want to understand how I can add a generrator as I cannot do it through the inverter
You can install a changeover switch after your inverter but before the earthleakage, where the 1 input is the inverter and the other the generator.
