May 21, 20233 yr Good day all For the last two weeks or so, my Deye inverter seems to go off-line for a few hours, and I can't see any statistics on Solarman for that offline period. I don't think it's my WiFi or internet as all other devices connecting to my router are fine. There is no interruption in performance of the inverter, just the connection to the Deye data-center. I have asked on my WhatsApps group if any one else experiences this, but it seems just me. I have re-booted my router. Prior to this, the connection was up 24-hours and I could look at all stats. Anyone have any idea or clues to this? These random issues are the worst 🙂 Thank you!!! An export of data shows the missing gap this morning: Updated Time 2023/05/21 02:45 2023/05/21 02:50 2023/05/21 02:55 2023/05/21 03:00 2023/05/21 03:05 2023/05/21 08:20 2023/05/21 08:25 2023/05/21 08:30 2023/05/21 08:35 2023/05/21 08:40
June 21, 20233 yr Hi, Rello I have the exact same problem. My Deye inverter and stick logger was working perfectly for 24 hours a day since August last year on Solarman Smart. However, on the 27th of March 2023, that all changed, and Solarman started showing portions data logged or none at all. Nothing changed on my side. On the Solarman app, my logger is online but my inverter offline. Have you managed to get a fix? Regards E
June 21, 20233 yr Author Hi there I did see another post some time back that spoke about changing the channel on my router. It was on Channel 6 and I moved it to Channel 11. I used a WiFi analyzer app on my phone that shows me all the channels and which are "crowded", possibly by neighbours routers. It's also useful to determine the WiFi strength by my logger - (it was quite strong enough) I also moved my router a bit - Raised it about 20cm - (put it on a box!) - Since then its been fine! 🙂 BTW- I have also recently bought a Solar Assistant - Device and software - Real-time solar monitoring from a Raspberry Pi | SolarAssistant Software (solar-assistant.io) - It's a SA product and pretty cool!!! Now - If you do try change the channel, check all your other devices, phones etc, still can connect. Some channels I tried my phone did not like! Good Luck.
June 26, 20233 yr Many thanks, Rello I'll give it a shot and see what happens. I'm very interested in the Solar Assist tech, but my use case is probably not strong enough to warrant the purchase of such when Solarman is enough. That is, if I can get it to work. Thanks again. Regards E
July 5, 20233 yr 5K Deye using the solarman App. I am having similar issues. However there is no Logger wifi to connect to in order to set up the device again . Pressing the button for 10s doesnt seem to help. It driving me crazy. anyone had any luck reconnecting their wifi dongle?
March 29, 20251 yr This happened to me too. I found what happened. You need to go to logger configuration again and set the network again. After that it worked normally. I found that it tried to connect to network name which is used during configuration (his own AP which disappear over time because it's necessary only at the beginning and then is not visible anymore)
July 26, 20251 yr First time posting here.I found the issue on mine was a loose connection on the board for the logger port. The white ribbon cable.Pushed the cable in where it looked loose and done.
