June 1, 20233 yr Hi Can someone assist or comment with regards to my Sunsynk Connect App that does not update (refresh) regulary. What is the refresh rate supposed to be? Are these somewhere I need to adjust the settings? Thanks
June 1, 20233 yr I stand to be corrected but the sync/refresh is about once per 5 minutes. When you're in the app, and older readings still show, just pull down the screen view to force an update, provided it's been more than a few minutes since the previous update of the readings. Not sure whether the app pushes a regular refresh once opened.
