SOL-I-AX-5M4
Any idea why my inverter will restart when it is on battery and hits 3000w but is 5600w, I changed battery to user and change the amps, it does not like it as it does the same once battery is charged full...just reboots, no alarms or fault codes.
Perhaps provide more info like inverter in question as well as battery installed.
Mecer inverter which I believe is rebranded Voltronic/Axpert 5.6 and Dyness B3 3.6kwh 48v battery
This battery an only supply 0.5C = 50Ax48V during discharge. This is 2400W load on battery power. You will never get 5.6kW load from the battery. If you need to draw a higher load you will have to get 1 or 2 more batteries.
