Question about battery charging voltages
Hi guys, first of all I love this forum and reading it last few days in order to learn as much as I can but still I am failing to understand what should be charging voltage of my system,
I have 5KW inverter https://voltronicpower.com/en-US/Product/Detail/Axpert-MKS-1KVA-5KVA
I also have 4 of there Exide batteries https://www.supac.co.uk/product/9004108/exide-gel-es2400
Only thing I was able to find regarding them is https://unimar.hr/Documents/product_manual/1240803_3_1.pdf where it says constant voltage should be 14.1
If you can share the what would be your recommended charging voltages it would be really helpful
This is my current setup
Bulk charging voltage: 57v
Float charging: 54.4
Battery cut off: 46v
Battery equalization is off
Edited by Nemke
Welcome Nemke,
Is there nothing on the battery labels itself regarding Bulk and Float?
In the absence of that, you listed doc states "With Solar System 14,2V constant", which I would translate as the Bulk based on these two bullet points.
U phase or U1 phase (main charging phase) with constant voltage between 14.1 and 14.4 V
U2 phase (charge retention) with constant voltage of 13.8 V
That would be 14,2V X 4 = 56,8V Bulk
13,8V (charge retention) X 4 = 55,2V Float
Stand to be corrected
Then also just as a reminder, try to stay above 50% SOC with any Lead Acid based battery type and they should give you many years of reliable service.
50% would be in the region of 48,3V.
It also refers to the 13,8V float but refers to the upper end of the bulk, i.e. 14,4V X 4 = 57,6V, but this they state should only be done once a month, which in my view is the typical equalisation process.
Let's see what the experienced Lead Acid users can add.
