Sunsynk Inverter SOC settings.
Good day
The System mode, time setting - SOC/V - used to reflect %. This changed from % tot V.  Currently reflects 49.0 V.
Will be grateful for suggestions to go back to %.
Regards
Lodie.
Someone changed the battery type from Lithium to AGM. In the Menu > Battery screen you will see it set there. You can change it by selecting Lithium or AGN % - then it will show the SOC on the system mode screen. However i would check with whomever changed it to AGM why they did that and if the Inverter + Battery combo can support the Lithium setting properly
