Deye 8kw parallel different battery voltages
As per heading, I have 2 8kw Deye inverters in a parallel install.
My issue is there is a battery voltage discrepancy between the 2 inverters. Of between 0.1 and 0.2 volts.
I have redone all connections between battery and inverters twice, and when I measure the voltage manually at the inverter battery connections with a voltmeter they are equal.
This causes some weird issues, such as at end of charge one inverter keeps "charging" the batteries while the other "discharges" them.
I have also tested this without load and under high current draw, and the voltage difference stays very similar between the inverters.
Anyone know of a way to calibrate the inverter voltage as the issue seems to be that they are simply measuring different voltages.
Edited by TehProd
  • 1 year later...
