June 14, 20233 yr Hi, I have 15 340W solar panels together with Voltronic type 5KWh Hybrid inverter and Pylontech lithium batteries, with load shedding I charge batteries from grid for 1 hour 19H00 till 20H00 in order to make absolutely sure we will be fine next morning. Question is, can I combine small wind turbine with the panels, rest of setup in order to bypass extra grid charging? weather, wind permitting, and if possible is it advisable?
