June 15, 20233 yr I am setting up an ECCO 3.5kVA 24V inverter. Right at the end a setting 46 comes up that says ndC and it is set to OFF. As I have no clue what this is, I am leaving it at OFF. Does anyone on this forum know what it is ?
June 28, 20233 yr On 2023/06/15 at 8:25 AM, Hannes Visagie said: I am setting up an ECCO 3.5kVA 24V inverter. Right at the end a setting 46 comes up that says ndC and it is set to OFF. As I have no clue what this is, I am leaving it at OFF. Does anyone on this forum know what it is ? On 2023/06/15 at 8:25 AM, Hannes Visagie said: I am setting up an ECCO 3.5kVA 24V inverter. Right at the end a setting 46 comes up that says ndC and it is set to OFF. As I have no clue what this is, I am leaving it at OFF. Does anyone on this forum know what it is ? Hi I've got the same inverter that setting doesn't show in the manual, but i know what it is, it is the settings for the Ah on your battery bank, so that it can display the correct amount of battery life left in your battery bank on the battery display screen. So if you say got 2×2 220Ah 12v batteries on the 24v inverter you can select 200Ah. If you got say 100AH 24v battery you can select 100Ah. Otherwise the level on the battery screen will not work 100%.
