July 1, 20233 yr I've open-sourced some Rust code that I'm using to dynamically adjust the minimum battery level on my Sunsynk inverter, using information from EskomSePush to adapt to load-shedding. I know some people are already doing similar things with Node Red and/or Home Assistant, but this might be useful for someone wanting a light-weight self-contained solution. It tries to do some smart things to avoid cycling the battery unnecessarily. https://github.com/bmerry/socit
