July 13, 20233 yr Hi how do I get a to change this can i get an electrician to do it or I go to Eskom directly
July 13, 20233 yr 4 minutes ago, Taps said: Hi how do I get a to change this can i get an electrician to do it or I go to Eskom directly 3 phase is more expensive so you can get the supply point changed. Even if this is done you still need the sparky to change the wiring in the DB. Further you can get a sparky to rewire the loads in the DB to single phase. Edited July 13, 20233 yr by Scorp007
