July 14, 20233 yr I just figured out why in the flow chart, my inverter was not displaying the power drawn from the grid. I checked a lot of advice and tried around a lot with the ct coil, but the reason for the issue was that the installer had connected the inverters grid connection after the breakers for the non-essential load in the db. That's why the inverter could not measure the power used. After connecting the inverters grid connection directly after the main breaker, the readings are now accurate.
