June 22, 20188 yr I have not been accessing my RPi ICC for quite a period of time, so I do not know when it started to happen. Today I logged onto my desktop using VNC and notice this error messages: Reboot, restart.. nothing seems to make it disappear. I do not have solar connected to my system although used to have. SMA's provide solar power and Axpert charges batteries from input power - Axpert think it is grid, but could be grid OR solar from SMA Licence valid to 29-03-2050. Any ideas / suggestions from the clever guys?
June 22, 20188 yr Author FOUND IT!!!! EASY TO SOLVE!!!! MQTT server was ticked: Although I have a MQTT server comissioned, but the interface does not cater for UID and PW which is required to publish to MQTT :-(
June 22, 20188 yr 18 minutes ago, fritserasmus said: suggestions from the clever guys? i am not clever but was it not for you solving the problem i would have suggested that your system was hacked
June 22, 20188 yr Author , I was the fool in this chapter. I introduced a MQTT server on my network for IoT and one day when I was on ICC saw this tick and suddenly that light in my head lit up as I knew what I could do with the feed. So I ticked it and filled in all the info. Sure enough I protected my MQTT server by adding UID and PW layer but ICC did not cater for that. So I did not give it a second thought and signed off. Obviously ICC gave up after a period of time not able to connect and reported it. Today that snake sneaked up on me and bit me. Well its sorted now. I suppose the question is: which ICC version allows MQTT UserId and PW........
