July 17, 20188 yr My system is totally offgrid, I recently installed Pylontech batteries and ICC (still busy sorting out) Is there any way to tell the ICC cutoff SOC? The only way I can see is setting ther Axpert voltage cuttoff. SOC setting only for back to grid. I have a Victron BM702 and can install this, this can then be used with external relay, is this my only option? Also, will the Victron monitor integrate 100% with Pylontech BMS if I do? There is Settings in ICC for both
July 17, 20188 yr Having chatted to Manie ICC takes input from either the BMV or the Pylontech not both.
July 17, 20188 yr Author 3 minutes ago, Chris Hobson said: Having chatted to Manie ICC takes input from either the BMV or the Pylontech not both. OK, there is a setting on ICC to allow both though, if both selected, not sure which it would prioritize
