Reverse light on electricity meter turns on when grid power to inverter is supplied.
No. This is a non reversible meter. It may even go forward (more than actual consumption). But it may cause the user liable of penalty for theft. Also note that these lights may turn on by just connecting the inverter to the grid even if the load wires are removed.
  • 9 months later...
Try to change inverter settings.
Program 1= sbu
Program 16= oso
I faced same issue , my settings  was
1.SOL and 16.OSO
When i change settings to
1.SBU and 16.OSO reverse and earth light problem solved.
  • 3 months later...
