September 20, 20232 yr Item: 16x Svolt 184ah Cells & accessories (I have 2 sets of these) Age: New Price: R27 000 per set R25 500 Payment Method Accepted: EFT is preferable Warranty: No Packaging: Some of the original packaging Condition: Brand new, unused Location: Fourways / Kyalami, Johannesburg Reason: Plans have changed Shipping: Yes, your cost & risk Collection: With pleasure Link: https://altergrid.co.za/product/svolt-184ah-3-2v-lifepo4-blade-battery-cell/ So I was planning on building 2x DIY batteries each consisting of 16 of these Svolt 184ah blade cells although plans have changed so they're going up for sale. I have pretty much all other accessories required to build the battery, below is a list of what I will include with each set: 16x Svolt 184ah Blade Cells (9.4 kWh) 1x JK 150A BMS (JK-B1A24S15P) with balancing cables & temp probes 1x JK BMS button 1x set of 5m silicone red & black cable & ring lugs to extend the balancing cables if needed 1x Set of busbars & clips to connect all cells in series 1x Set of nuts & washers to secure the busbars 9x Wago PCT223 Connectors to easily extend the BMS balancing cables (if needed) As mentioned, I have 2 of these sets and each set would build a 51.2v battery with a total of 9.4 kWh. If you were to take both you'd then be sitting with 18.8kWh of batteries for under R55k, some of the parts are not available locally and I have to import them (like the clips & busbars) These are LiFePO4 cells, they are brand new first life cells and are 1C rated. At this price it works out to R2872.34 per kWh Edited September 26, 20232 yr by PsyCLown
October 4, 20232 yr Author I am willing to split if someone would prefer to buy separately. Everything is brand new and unused. Cells, busbars, clips, washers & nuts = R22 800 for the below 16x Svolt 184ah Blade Cells (9.4 kWh) 1x Set of busbars & clips to connect all cells in series 1x Set of nuts & washers to secure the busbars BMS with the power button, extra silicone wire & Wago connectors = R2700 for the below 1x JK 150A BMS (JK-B1A24S15P) with balancing cables & temp probes 1x JK BMS button 1x set of 5m silicone red & black cable & ring lugs to extend the balancing cables if needed 9x Wago PCT223 Connectors to easily extend the BMS balancing cables
October 4, 20232 yr I am willing to split if someone would prefer to buy separately. Everything is brand new and unused. Cells, busbars, clips, washers & nuts = R22 800 for the below 16x Svolt 184ah Blade Cells (9.4 kWh) 1x Set of busbars & clips to connect all cells in series 1x Set of nuts & washers to secure the busbars BMS with the power button, extra silicone wire & Wago connectors = R2700 for the below 1x JK 150A BMS (JK-B1A24S15P) with balancing cables & temp probes 1x JK BMS button 1x set of 5m silicone red & black cable & ring lugs to extend the balancing cables if needed 9x Wago PCT223 Connectors to easily extend the BMS balancing cables I might be interested in a JK BMS but only 8 cells if the BMS can be started with 8 Please PM me for private details.
October 4, 20232 yr I am willing to split if someone would prefer to buy separately. Everything is brand new and unused. Cells, busbars, clips, washers & nuts = R22 800 for the below 16x Svolt 184ah Blade Cells (9.4 kWh) 1x Set of busbars & clips to connect all cells in series 1x Set of nuts & washers to secure the busbars BMS with the power button, extra silicone wire & Wago connectors = R2700 for the below 1x JK 150A BMS (JK-B1A24S15P) with balancing cables & temp probes 1x JK BMS button 1x set of 5m silicone red & black cable & ring lugs to extend the balancing cables if needed 9x Wago PCT223 Connectors to easily extend the BMS balancing cables Thanks for offering us an opportunity to buy the cells. A pity you could not put them in service yourself.
