September 28, 20232 yr Hello! Anyone using "low power mode"? It doesn't work for me. I have a parallel system of two SUN-6K-SG03LP1-EU inverters. Low Bat set as 51.2 Volt. Time Of Use Voltage set as 51.1 Volt. Checker for "Low Power Mode<Low Batt" set is on. Grid is connected. PV is disconnected. The battery voltage reaches 51.1 volts. But the inverters do not switch to the low power mode. Anyone have any ideas?
