Geyserwala Connect
Evening Folks
After seeing a post about thingwala and getting your geyser connected to the internet, I purchased a geyserwala connect.
The install was easy enough after watching the install video, my biggest delay was that the data cable was a little short, the installers of my solar geyser glued it to the wall. The Wi-Fi connects easy enough, but just be aware, if your IP addresses does not start with 192.168.x.x, you will need to set the IP in manually on the geyserwala.
Once online and the online token was installed the geyserwala worked flawlessly, I set in the setpoint temperatures and setup the timers and could not be happier.
The service was awesome. If you looking to future proof your geyserwise unit, geyserwala connect is the way to go.
