October 6, 20232 yr Hi, I once found on github information on how to connect a LilyGO / T-CAN485 device with DEYE. Unfortunately, I can't figure out how to do it. I changed GPIO to 21 and 22 but it still doesn't connect. Is there something else I should change in the code? Thanks for your reply!
October 9, 20232 yr Author I managed to solve the problem. You should add 5V power supply to the rs485 chip to the code. output: - platform: gpio id: ENABLE_PIN # Enable the chip pin: number: GPIO19 inverted: true - platform: gpio id: SE_PIN # Enable autodirection pin: number: GPIO17 inverted: true - platform: gpio id: ENABLE_5V_PIN # Enable 5V pin for RS485 chip pin: number: GPIO16 inverted: true uart: id: mod_bus rx_pin: GPIO21 tx_pin: GPIO22 baud_rate: 9600 stop_bits: 1
December 4, 20232 yr On 2023/10/09 at 1:28 PM, Dariusz said: I managed to solve the problem. You should add 5V power supply to the rs485 chip to the code. output: - platform: gpio id: ENABLE_PIN # Enable the chip pin: number: GPIO19 inverted: true - platform: gpio id: SE_PIN # Enable autodirection pin: number: GPIO17 inverted: true - platform: gpio id: ENABLE_5V_PIN # Enable 5V pin for RS485 chip pin: number: GPIO16 inverted: true uart: id: mod_bus rx_pin: GPIO21 tx_pin: GPIO22 baud_rate: 9600 stop_bits: 1 hi @Dariusz i am in the same situation as you in my case i have a deye 8k that i would connect via can and then a bms jk that manages some 16s x 304ah cells. have you been able to connect it at this moment with a bms or how do you use the lilygo ?
January 16, 20242 yr Author Yes, everything works. I have a connection to the inverter and to the battery (BMS SEPLOS) Edited January 16, 20242 yr by Dariusz
