Best 5kw system
Good day
I want to get myself a solar kit, problem is my budget is very tight, R65k. Which 5kw inverter and battery would best soot my need. I want to save on my electricity bill as well meaning my excess power must go to my non-essentials. Will add panels as well. just need the best 5kw system for my budget.
I looked at the lux power SNA5000 inverter but apparently it cannot push excess back to non essentials. Can anyone give me a bit of advise please?
5 hours ago, Lendl said:
Good day
What loads do you want to be connected to the non essential.
My line of thinking is a SNA with panels without battery but with panels feeding non essential.
A 2nd SNA with panels and battery for essentials.
5kwh Must battery R17th
2 x SNA R22th
This gives you 4 strings of panels for the 4 x MPPTs. Minimum of 3 panels per string  and maximum about 7x4x455W. This gives from 6-28 panels.
Depending on panels it could get you within your budget.
