October 24, 20232 yr Good day I have installed a 16kva sunsynk inverter and struggling to get it approved by coct because it is over 13kva. The inverter setting are set at a maximum of 13kva but still not getting approved. is there any work around? Kind regards
October 24, 20232 yr 51 minutes ago, JacobHC said: Good day I have installed a 16kva sunsynk inverter and struggling to get it approved by coct because it is over 13kva. The inverter setting are set at a maximum of 13kva but still not getting approved. is there any work around? Kind regards Sunsynk 16kw is on coct approved inverter's list. Take the list and show them it is on the list of approved inverters. Approved Photovoltaic (PV) Inverter List(2) (1).pdf
