November 21, 20232 yr I picked up one of these 'cheap' 2KVA inverters to keep my home office running during power outages. I've noticed that the battery indicator never stops flashing as if it's never full. The top bar always flashes. Is this how some inverters are, or could I have a problem on my hands? WhatsApp Video 2023-07-25 at 14.11.26.mp4
November 21, 20232 yr 8 hours ago, gryphon25 said: I picked up one of these 'cheap' 2KVA inverters to keep my home office running during power outages. I've noticed that the battery indicator never stops flashing as if it's never full. The top bar always flashes. Is this how some inverters are, or could I have a problem on my hands? WhatsApp Video 2023-07-25 at 14.11.26.mp4 How long have you been charging the battery? 13.5V is not fully charged yet if the display is correct. These inverters were designed for lead acid and the top bar could only be on at a voltage higher than what the lithium would be charged. What size battery do you have? What is your AC charge current set at under settings?
