December 16, 20232 yr Does anyone know how UPS settings on inverters actually works? seems like the transfer time in less in UPS than APL, I would like to get deeper into how this works I tried it on Growatt SPF 5000 ES and some Voltronic inverters.
December 16, 20232 yr 1 hour ago, Taher Sylla said: Does anyone know how UPS settings on inverters actually works? seems like the transfer time in less in UPS than APL, I would like to get deeper into how this works I tried it on Growatt SPF 5000 ES and some Voltronic inverters. Yes all the manuals show that APL is around 20ms and UPS around 10ms. Both allow you to set it. Then there are others with zero time. Edited December 16, 20232 yr by Scorp007
December 16, 20232 yr Author 2 hours ago, Scorp007 said: Yes all the manuals show that APL is around 20ms and UPS around 10ms. Both allow you to set it. Then there are others with zero time. Yes I know this, but I want to know how does the UPS works so that the transfer time is less than APL, I mean technical details
December 16, 20232 yr 3 minutes ago, Taher Sylla said: Yes I know this, but I want to know how does the UPS works so that the transfer time is less than APL, I mean technical details Normally volts do not drop in a flash say from 180 to the lower level before a switch over is triggered on APL which could take longer. Sorry not a technical answer. Hope someone can help you.
