Mecer SOL-I-AX-5P64 settings for Svolt 48 V
Good day All
I bought a new Svolt battery for a system I inherited when we moved into a new rental house.
The old lead acid batteries are shot.
Can you please help me with the settings for the battery as I believe they need to be user defined.
Battery stats as per internet: Svolt 48V 106AH
I tried searching for it but cant seem to find it.
Regards
Gerhard
On 2024/01/02 at 8:12 AM, Gerhardd said:
Good day All
Regards
Gerhard
The settings are as per the electric parameters you supplied.
Start with a bulk of 52.5V
Then float at 52V.
Inverter cut out 43V
Grid charge current of 40A.
If no panels use grid + solar as 40A too.
This should get you going for now. These leave scope for adjusting as you use it.
