January 6, 20242 yr This is the first time I have seen something like this. I got a warning for "Frequency out of range" on my Luxpower 5kw inverter and sure enough it was above 55hz. This was during load shedding (22:00~00:00). Could this be due to someone running a dodgy generator in the neighbourhood? Perhaps equally concerning is that the inverter latched on to that out of spec Hz for the EPS, but that is a different story.
January 6, 20242 yr 7 hours ago, Rouxenator said: This is the first time I have seen something like this. I got a warning for "Frequency out of range" on my Luxpower 5kw inverter and sure enough it was above 55hz. This was during load shedding (22:00~00:00). Could this be due to someone running a dodgy generator in the neighbourhood? Perhaps equally concerning is that the inverter latched on to that out of spec Hz for the EPS, but that is a different story. One can only think it can be a generator as it was during LS. A hefty genny unless it is a low load to the consumers on the mini sub.
