January 11, 20242 yr Hi all, Not sure if the SA devs read these posts. So since JHb City Power updated their schedules AGAIN, the source SA uses to for schedules is out of whack again. Somehow I don't think that source currently used is updated frequently and this can mess with the new automations in SA. EskomSePush (ESP) are now giving away API keys again for personal use - so could we possibly get a feature in SA to input our own API keys and then SA uses their API to get the info? Link to get an API key for personal use: https://eskomsepush.gumroad.com/l/api Cheers Douw
January 11, 20242 yr 1 hour ago, Douw G. Gerber said: Hi all, Not sure if the SA devs read these posts. So since JHb City Power updated their schedules AGAIN, the source SA uses to for schedules is out of whack again. Somehow I don't think that source currently used is updated frequently and this can mess with the new automations in SA. EskomSePush (ESP) are now giving away API keys again for personal use - so could we possibly get a feature in SA to input our own API keys and then SA uses their API to get the info? Link to get an API key for personal use: https://eskomsepush.gumroad.com/l/api Cheers Douw You can open a Github issue to request an update or submit your own for approval https://github.com/beyarkay/eskom-calendar#contributing
January 17, 20242 yr CoJ Load Shedding schedules fixed on Eskom Calendar github via pull request 514 https://github.com/beyarkay/eskom-calendar/pull/514
