December 11, 20187 yr Good day All. Can someone assist me with what is the problem with the program as I am not able to download a comprehensive data sheet or chart only getting one reading up here by 12, plus the event logger is also disfunctional. The Charts axis are not marked properly, as the scale is 0 to >12, I summise that it is in months but could be anything. Plus the battery % and and voltage is not function (reading) correctly. Another problem is that the program downloads its information to pdf, which is not the best of programs when you are required to calculate reading/setting. Can someone assist, it will be much appreciated. Wiliam
