venus pi / mqqt or dbus voltage logging?
Any recommendations on what the current method du jour is for logging battery on a PI /Venus?
I see MQQT can be used.  Ideally, I'd like something web / cloud based.
At home would like to keep power usage low, so ideally an mqtt broker running on the existing pi running venus/pi publishing somewhere would be ideal.
I've had a brief google, and found this https://hackaday.com/2017/10/31/review-iot-data-logging-services-with-mqtt/. which mentions some services.
Will it just be a matter of
1) installing a broker service, and cron script to push info to a cloud server.
2) turning off automatic updates so that doesn't get nuked?
Or is there something else suggested?
Answering myself here.  I setup ssh on the pi using instructions here - https://www.victronenergy.com/live/ccgx:root_access
Have added an mqtt conf under /data/conf/mosquito.d/
Busy trying to config it to work, playing around with settings.
logging is under /var/log/mosquitto/current
eg
tail -F /var/log/mosquitto/current
Looks very tai64n style! a la qmail
Not being successful so far though, seems to just sit and wait.
tail /var/log/mosquitto/current  -F | tai64nlocal
initial errors are due to the bootup, no networking at that point
2018-12-25 08:39:54.493228500 1545727194: Connecting bridge ccgx (io.adafruit.com:1883)
2018-12-25 08:39:54.493235500 1545727194: Error creating bridge: Temporary failure in name resolution.
2018-12-25 08:39:54.493239500 1545727194: Warning: Unable to connect to bridge ccgx.
2018-12-25 08:39:54.493243500 1545727194: Connecting bridge vrm (mqtt.victronenergy.com:443)
2018-12-25 08:39:54.493248500 1545727194: Error creating bridge: Temporary failure in name resolution.
2018-12-25 08:39:54.563427500 1545727194: Warning: Unable to connect to bridge vrm.
2018-12-25 08:40:05.070782500 1545727205: New connection from 127.0.0.1 on port 1883.
2018-12-25 08:40:05.084617500 1545727205: New client connected from 127.0.0.1 as ve-dbus-mqtt-py (c1, k60).
2018-12-25 08:40:24.632157500 1545727224: Connecting bridge ccgx (io.adafruit.com:1883)
2018-12-25 08:40:28.026899500 1545727228: Connecting bridge vrm (mqtt.victronenergy.com:443)
My conf file looks like this at the moment - guess once I get some errors, I'll be able to troubleshoot further.
(PASS obfuscated below for obvious reasons)
If I can't get it going, will probably setup a local mqqt openhab or similar.  Would like to keep minimal local stuff running though.
#https://io.adafruit.com/shanghailoz/feeds/wood-close
connection ccgx
address io.adafruit.com:1883
cleansession false
notifications false
bridge_attempt_unsubscribe false
try_private false
start_type automatic
remote_clientid wood-close
remote_username shanghailoz
remote_password PASSGOESHERE
topic N/b827eb23998f/solarcharger/+/Dc/+/+ out 0
topic N/b827eb23998f/solarcharger/+/Pv/+ out 0
topic N/b827eb23998f/vebus/+/Ac/Out/+ out 0
topic N/b827eb23998f/vebus/+/Ac/ActiveIn/+ out 0
topic N/b827eb23998f/vebus/+/Alarms/# out 0
topic N/b827eb23998f/vebus/+/Leds/+ out 0
topic N/b827eb23998f/vebus/+/State out 0
topic N/b827eb23998f/battery/+/Dc/+/+ out 0
topic N/b827eb23998f/battery/+/Relay/+/+ out 0
topic N/b827eb23998f/battery/+/Alarms/+  out 0
topic N/b827eb23998f/battery/+/Soc out 0
topic N/b827eb23998f/battery/+/TimeToGo  out 0
Continuing this -
Still no luck, getting somewhere with finding out the mqqt details though.
brew cask installed mosquitto_client so i could troubleshoot.
Console #1 (watching);
mosquitto_sub -h 192.168.8.100 -t '#' -v
Console #2, to push the data.
mosquitto_pub -h 192.168.8.100 -t 'R/b827eb23998f/system/0/Serial' -m ""
Looks like the droids i was looking for were
N/b827eb23998f/system/0/Dc/Battery/Current {"value": -2.5}
N/b827eb23998f/system/0/Dc/Battery/Power {"value": -68.874998092651367}
N/b827eb23998f/system/0/Dc/Battery/Voltage {"value": 27.549999237060547}
A quick edit of the conf file to:
topic N/b827eb23998f/system/0/Dc/Battery/Current out 0 current shanghailoz/feeds/wood-close.current
topic N/b827eb23998f/system/0/Dc/Battery/Power out 0 power shanghailoz/feeds/wood-close.power
topic N/b827eb23998f/system/0/Dc/Battery/Voltage out 0 dc shanghailoz/feeds/wood-close.voltage
and some adding of fields at adafruit.io, and still not working, gah!
Will have to play later, off to xmas lunch.
Edited by shanghailoz
Daemontools. It is very much the same software that is used by qmail. DJB made it public domain some years ago. It's still one of the cleverest ways I've seen to monitor a process (force it to inherit a file descriptor and then use some posix trickery to detect if the remote end still has the socket open... :-) ).
The thing most people struggle with with using mqtt, is that the data is only sent if you ask for it periodically. There is a kind of keepalive set up. It's all in the dbus-mqtt documentation on github. This keepalive is there to cut down on unnecessary amounts of traffic.
