February 22, 20242 yr Is any one using such an lithium is your volts simulator to this lithium. Testing this lithium . Volts rest at 49.9 volts in the evening is this normal for this lithium as Hubble am 2 that I'm used to rest around d53 v Inverter is set to communicate with with lithium so at 53.3 volts inverter stops charging till the lithium rests back to 49.9 volts then charges again to around 53v but soc stay at 100% and all 6 lights on battery show full . If I set to use and set bulk and float to +-53v played around with volts the bms cut the charging but the inverter still wants to charge so the volts jump around . Inverter is an Ecco 5.5 kw
