February 1, 20197 yr Hi guys still on research for my backup system...have decided that getting the above and mating it to a venus gx makes more financial sense. My query is...will be getting 1st generaticn easysolar 48/3000va with two 150/35 mppt chargers, Venus gx and bmv 702...since venus gx has two V.E direct ports, is there of networking the two mppts to work as a single unit the connect it to the GX and the other port used for BMV?..Sorry for the long story...newbie here
February 1, 20197 yr 49 minutes ago, Aizen79 said: since venus gx has two V.E direct ports, is there of networking the two mppts to work as a single unit the connect it to the GX and the other port used for BMV? The 2 ports I would use for the two MPPT's. The USB port for the BMV with a VE.direct to USB cable.
February 1, 20197 yr O less I not mention: The other USB port can be used for the Carlo - if you are adding that too. And if you need more ports, by using the one USB port, you can connect a USB hub to it, and have more ports than you will ever use. 🙂 Edited February 1, 20197 yr by Guest
February 1, 20197 yr Author 12 minutes ago, The Terrible Triplett said: The 2 ports I would use for the two MPPT's. The USB port for the BMV with a VE.direct to USB cable. thanks I will do this
