Solar panel wiring
On 2024/05/15 at 5:52 AM, Carlkat said:
Mecer 5kw 48v inverter. What is the best way to connect my8x 24v 300w solar panels to this inverter
I think you need to be more specific in giving your model of Mecer inverter. They come with different types of charge controllers, and that makes a difference in the panel layout. Otherwise, give a snapshot of the PV input specs on the side plaque of the device. While you're at it, please give the full specs of the PV panels you're using.
