May 15, 20242 yr Mecer 5kw 48v inverter. What is the best way to connect my8x 24v 300w solar panels to this inverter
May 20, 20242 yr When I was first looking into it, I felt pretty overwhelmed too. But once you break it down, it’s not so bad. The key thing to remember is that you’re dealing with direct current (DC) from the panels, which needs to be converted to alternating current (AC) for most home appliances. That’s where your inverter comes in. From my experience, the most important part of wiring is ensuring all the connections are solid and weatherproof. This prevents any loss of efficiency and keeps everything safe. Also, you’ll want to consider the placement of your panels and inverter to minimize the length of wire runs, which helps reduce energy loss. I went with a local company, solar panel installers ireland, and they were fantastic. Edited May 20, 20242 yr by Lagencery
May 20, 20242 yr On 2024/05/15 at 5:52 AM, Carlkat said: Mecer 5kw 48v inverter. What is the best way to connect my8x 24v 300w solar panels to this inverter I think you need to be more specific in giving your model of Mecer inverter. They come with different types of charge controllers, and that makes a difference in the panel layout. Otherwise, give a snapshot of the PV input specs on the side plaque of the device. While you're at it, please give the full specs of the PV panels you're using.
