May 31, 20242 yr Hi everyone. I have a strange issue with my 5kw Deye inverter. The CT coil and "zero export to ct" was working perfectly until I had to do a firmware update to fix another issue. Now the the non-essential load no longer shows as part of the house consumption. Only the essential consumption shows and no matter what settings I change it shows only the essential consumption. Toggling between "zero export to ct" and "zero export to load" makes no difference to the house consumption reading. Any advice will be appreciated.
May 31, 20242 yr Author 6 hours ago, JL10 said: Hi everyone. I have a strange issue with my 5kw Deye inverter. The CT coil and "zero export to ct" was working perfectly until I had to do a firmware update to fix another issue. Now the the non-essential load no longer shows as part of the house consumption. Only the essential consumption shows and no matter what settings I change it shows only the essential consumption. Toggling between "zero export to ct" and "zero export to load" makes no difference to the house consumption reading. Any advice will be appreciated. Problem solved. The guys who came to fix the other issue moved the CT Coil. All fixed again.
