July 5, 20242 yr Hello, I was wondering if anyone could help. I have panels (that I want to install) that use the following PV-LR5 connector (technical documents attached): Would there be an issue if I used the TOSUNLux MC4-1 Connector (see below) to connect my panels to the inverter (via the combiner box)? If it is a problem, could someone recommend a compatible MC4 connector to link up to the PV-LR5 connector? Many thanks in advance! LONGI-LR5-Manual.pdf Datasheet LR5 Connector V1.pdf Edited July 5, 20242 yr by rgt.dnl uploaded technical documents
