July 25, 20241 yr Hi all. I just bought a MUST LP1600-24200 battery. Accorging to the manual, I can set the protocol in the settings on the screen, but when I go into "Para" I get "--Non production manufacturer can not use". I'm guessing there is some key-combo to get the battery into installer mode? Any ideas? This is to connect to my Growatt SPF-3000 Inverter. I'm guessing setting both to the same protocol will do the trick. Thanks
August 19, 2025Aug 19 On 2024/07/25 at 7:12 PM, FrancoisVN said:Hi all.I just bought a MUST LP1600-24200 battery. Accorging to the manual, I can set the protocol in the settings on the screen, but when I go into "Para" I get "--Non production manufacturer can not use". I'm guessing there is some key-combo to get the battery into installer mode? Any ideas?This is to connect to my Growatt SPF-3000 Inverter. I'm guessing setting both to the same protocol will do the trick.ThanksDid you get the solution? I am facing the same issue.. However on PACEEX BMS App I can see two protcols to set but still Voltronics is not there..
