Sunsynk 5,32 on beta 2024-08-27
Having issues since the last beta upgrade
my install is a sunsynk 8 kw hybrid with 2 X 5,32 sunsynk batteries.
RS485 to inverter and RS232 to the master battery.
all was well until the 2024-08-27 upgrade, all readings were working on previous version and both batteries detected.
symptoms are that only one battery is being reported now and all battery load readings are exactly half, it's as if the second battery is not being seen.
what I've done:
cycled power on UPS and batteries
cycled power on the orange PI
checked all connections
reported the issue to solar assistant
has anyone else picked up a similar issue?
what temporary fixed it is to use inverter values, but this defies why I'm using solar assistant to monitor the batteries as I get (or rather got) a ton more info from them.
hoping SA has a fix for this as I do not believe it's a hardware issue on my side.
Suggest reporting the issue directly to info at solar-assistant.io
I'm on
2024-08-27 beta 64 bit on RPI4 and that seems fine.
I have Hubble AM2 batteries.
