alternative to sonoff miniR4 for din rail
I am using sonoff miniR4 to control light in my home.  The miniR4 are either placed in the switch box or in the distribution board.  When in the distribution board, I would like to find a way to fix them neatly on the din rail... but so far no luck.  When no physical switch is needed (pool pump, geyser...) I use a smart wifi circuit breaker which fits nicely onto the din rail... unfortunately all these do not have a connection to a switch.
I would appreciate if someone could help me to find an ewelink compatible wifi switch that fits onto a din rail and can be connected to a physical switch (pulse mode) like the miniR4.
 We do have a din rail mount for the Sonoff MiniR2 that was made in fireproof filament 2d print, It’s on our site.
I would recommend going with the Sonoff Dual R3 it will give you 2Ch and 2 inputs 220 volt. And has the can measure power. It has a S1 and S2 input port to control the out puts.
Its a bit small for Geyser and Pool but great for lights and Automation.
For Pool/Geyser I would always go with POWR320D they just such excellent workers and never fail.
Aleks
Sonof Africa
