November 17, 20241 yr Is there any solution to the attached video ? I normally upgrade them, but this one when I pressed FLASH using ISP TOOLS 4.3 ( as usual ), it stopped and not showing anything, and it is not accepting any firmwares ( originally 67.01/68.01 and I was flashing 67.03/68.03 ) The communication board after I press FLASH shows steady red and blue light, or it only shows steady blue light, also sometimes the inverter does communicate with the laptop as when I press TEST in ISP TOOLS, but when I press FLASH the program freezes and gives me a message that says that the device attached is not functioning. I'm in Syria and ordering a new control board would cost alot of money and takes alot of time, did any one encounter this ? This is the second time this happens to me, and they were some new inverters that came to the country so I don't know I'm confused Here is the video https://drive.google.com/file/d/1-1xdHdvmv2ndMFWgma4xImoS3JKs16f8/view?usp=drivesdk Also another update, while attempting to install the firmwares, now the inverter screen is blank, while the three lights above it still blinking
November 18, 20241 yr I have only found this method , but I am afraid that you cant find xds100v2 DSP Chip EMULATOR https://www.amosplanet.org/how-to-activate-control-board-of-off-grid-inverter-that-failed-upgrading/ also check https://www.amosplanet.org/how-to-solve-that-off-grid-inverter-cant-be-switched-on-or-lcd-screen-is-off/ amosplanet is a good site to check if you need help with Growatt
November 18, 20241 yr Author Unfourtunetly the didn't work, non of these, except for "how to activate control board" I didn't have the equipments for that so I can try it, I will be checking if I can get the equipment asap
