Low profile thermostat for geyserwise ptc element install
Does anyone have advice on low profile thermostat options for geyserwise ptc element installs that don't have the full geyserwise setup?
I currently have a kwikot geyser and I've installed the ptc element, geyserwise flange and thermostat tube.
The thermostat i have is the standard kwikot one that plugs into the standard spiral element, so there are terminals that are basically in the way of a flush fit into the thermostat tube.
The main issue is I can't close the geysers plastic protective cover over the element and thermostat, so they are a bit exposed to the elements at the moment because my geyser is mounted outside.
First prize is to get a thermostat that fits better.
Alternatively, I'll have to make a custom cover to fit better.
Geyserwise specify that you use the satchwell vfk11 in this use case (get the proper satchwell brand).
We have quite a few like this.
Geyserwise email and phone technical support is top notch if you need assistance.
Thanks, I will look for this one.
Just now, abd7 said:
Also note the position of your thermostat tube, it MUST be at 10am or 2pm (relative to the element) to function correctly.
I have it at 10am. Think that's the only way the flange would fit in my geyser to be honest.
