November 30, 20241 yr I recently purchased two Shoto 5.1kwh batteries, but I’ve been having some trouble with them. The main issue is that I can’t use the LI mode because I can’t change the charge input from 5 amps to more amps. So, I’ve been using the USE mode, where I set my charge settings to 25 amps. This works great; it charges very fast. But the problem is, it sometimes goes into fault mode, and I can’t seem to fix it on my own. I’m hoping someone here might have had a similar issue and knows how to fix it. If you have any suggestions, please let me know!
