January 23, 20251 yr Good afternoon. I just bought this Lumo 2.5kW UPS that I was recommended. I wanted to connect it to my DB board but I am wondering if I need to earth the metal case of the UPS when I connect it? Please could some one explain if i need to or not. Thank you!
January 31, 20251 yr Generally you should not have to, as the manufacturer should already earth it... If you do (as extra precaution), it should not be a problem. Do you have a diagram on how you want to connect it to the DB Board and what you are backing up?
