January 23, 20251 yr Hello there. I am a bit confused, I have been doing some research on some products and installation guidelines. I noticed that the requirements for a COC to be approved is that it needs a PE-N (earth, neutral connection) for the inverter to get rid of unwanted voltage on the earth. I myself have a Luxpower 8kW inverter and 1 Lumo 5.12kW battery. But I dont see this PE-N connection in my system, but I have a COC? I also saw that some inverters have a 'Neutral earth relay' built in. Is this why I dont have a separate earth neutral connection in my system?
