6 off Pylontech US3000C for sale
SOLD!!!
Item: Pylontech US3000C
Age: new in July 2022
Price: R11000 each
Payment Method Accepted: EFT, Cash, BTC, XRP, USDT.
Warranty: balance of OEM warranty left.
Packaging: bubble wrapped or as agreed. Interconnecting power cables included as well as coms cable.
Condition: used but no signs of aging. Well kept.
Reason: relocating and no use for them
Shipping: to be discussed, after payment of a deposit
Collection: in Malvern, Durban
These batteries are being used in a working system with a Deye 8kW inverter. They are in perfect working condition. I have 6 for sale and all connected in parallel. If all 6 are taken a bulk discount of R6000 will be given. US3000C_1200x.thumb.jpg.390b06813a903cdb04894e33df7b08ab.jpg
Edited by Vishal
Sold
Installed in July 2022. DoD set at 40% when grid or generator starts charging. Worst case is 1 cycle per day. Plenty of life still in these batteries. I would estimate around 900 cycles done with each of these.
Edited by Vishal
Additional information
Pylons are notoriously sensitive to how well they are treated - you will make your life a lot easier selling these if you connect a PC to the console port and extract exact cycle data and logs via BatteryView.  That way people will know what they are buying, and you will be able to get a fair price.  Failing that, I suspect that potential buyers would assume the worst.
2 other points:
The picture you show is a US3000B, not a US3000C.  They are significantly different.
These are now available brand new for R15k. Pylon US3000C 3.5kWh Li-Ion Solar Battery (excl. brackets)
Thanks for the tip, I will do that and post results here.
I used a pic from the store under US3000C so it's not actually a pic of mine. I can post real pics but they are connected to each other and the inverter.
I have seen the new ones for R15k prior to posting...are you hinting that I am asking for too much for the used ones?
All depends on what the logs say - if there are many overvoltage events (the sort of thing that might Pylontech refuse warranty claims) it will adversely affect the value.
Your price might be OK if the batteries are in perfect condition.  That is why I suggested you publish the logs - you will need them to get your price.
Anyway, good luck!
I managed to get a cable, read the logs for each of the batteries, and updated the software on each from version 1.4 to version 2.4
Will send these to persons interested in buying...
On 2025/01/29 at 7:32 PM, FixAMess said:
How many cycles, SoH?
From the logs the battery cycles are from 299 on the battery with the lowest and vary to up to 343 cycles for the highest one.
1 hour ago, Vishal said:
Sorry guys, these have been sold but I don't know how to remove this post...
Edit your original post - mark as sold.
