February 11, 20251 yr Hey guys , looking for some advice regarding my current setup. the idea was to get a kodak inverter but unfortunately non was available so had to go with alternative one that fits my needs/specs in a sense now its a conderenergy 10.2Kw inverter so far it works great my only problem @ this stage is the lithium battery i have bought its a FiveStar 15kw beast also works great. can't get it to communicate to inverter so what it does it sometime just goes into fault mode and only way to get it to work again is by disconnecting the bms cable other than that it works. is there any specific settings for bms i need to look at to get it to work as intended?
