February 24, 20251 yr Hi guys, This one is bogging my mind. I have a 2.4kva mecer Kool energy inverter. When connected all is fine runs my TV, data cabinet etc.When I test & switch Eskom off batteries kicks in and max load about 30%. Switch Eskom on and all is ok still. Then we have load shedding. Inverter kicks in no issues, at 2hours the inverter battery status is 68%. Then power is restored and the inverter starts beeping. No errors on the screen and the load still sits at 28%. Beeps continuously the switches off. I remove the load and inverter still beeps. Not sure if the function settings are correct. Does anyone know this inverter well? Regards Mr Nak WhatsApp - 0834154574
February 25, 20251 yr 5 hours ago, KubenMNC said: Hi guys, This one is bogging my mind. I have a 2.4kva mecer Kool energy inverter. When connected all is fine runs my TV, data cabinet etc.When I test & switch Eskom off batteries kicks in and max load about 30%. Switch Eskom on and all is ok still. Then we have load shedding. Inverter kicks in no issues, at 2hours the inverter battery status is 68%. Then power is restored and the inverter starts beeping. No errors on the screen and the load still sits at 28%. Beeps continuously the switches off. I remove the load and inverter still beeps. Not sure if the function settings are correct. Does anyone know this inverter well? Regards Mr Nak WhatsApp - 0834154574 What kind of equipment/load are you running that makes up the 28-30% of the load rating of the inverter.
