Battery Charging Anomaly
I have a 8kw Sunsynk Inverter and 2 x 5Kw Hubble batteries, I have noticed that since load shedding started again, when my batteries discharge they only charge to 90% and then "trickle" charge the rest of the way at like 100w as can be seen on the image. I am not aware of any setting that changed and prior to this they would charge fully from Grid once the power was restored. Can anyone point me in the right direction to check a setting that might be causing this.
I do have access to the Synsync App as an installer in order to make changes
Edited by Chad.Robin
Spelling
