Axpert Max II 11kW '2809 non-Twin firmware
This is patched firmware version x63.05, based on factory firmware version 63.05 for the Axpert Max 11kW '2809 non-Twin. Do not use with any other model. The hex file is dated 04/11/2024.
This firmware works around the "stuck at 90 V" problem by changing the current threshold from 0.50 A to 0.10 A. It also fixes the premature float bug, and changes the reported version number to x63.05. The internal display will continue to show version U1 63 05.
Use at your own risk; I cannot test this firmware as I do not own an Axpert Max. It has been "sanity checked" by disassembling the firmware and confirming that the intended changes are present.
263.05 has a minimum MPPT voltage of 200 V.
163.05 has a minimum MPPT voltage of 150 V.
963.05 has a minimum MPPT voltage of 90 V; use only if you have very low PV voltage (e.g. 4-5 72-cell panels in series). It still has all the other patches, e.g. the lowered current threshold.
dsp_original.hex has the factory firmware version 63.05.
dsp.hex is the same (when unzipped) as 263.05.
To use a different hex file, first delete dsp.hex, then duplicate (copy and paste) the chosen hex file in a file explorer, and finally rename the resultant file to dsp.hex. Unfortunately, this reflash tool only looks for the file dsp.hex. Do this before running the reflash tool.
Firmware upload instructions.
dsp_x63.05_patched_MaxII_11kW_2809_nonTwin.zip
version → model
