Axpert MKS 1k replace the mppt with pwm controller
Hello guys,
i have inverter Axpert MKS 1k 12V mppt and i replaced the solar controller with pwm controller (the controller is for Axpert 1K pwm inverters) but its not working,
any one have an idea why its not working.
for knowledge i updated the firmware for the inverter with ver15.61 firmware but nothing happened.
I have read of one reader that did this successfully on a higher power model.
The 12 V models usually have exceptionally small main processors (8-bit, tiny flash space), so maybe they don't have enough flash space to accommodate this change.
It's also possible that the 12 V Solar Charge Controllers have different processors on them, such that this change is not possible. But I'm guessing wildly. My experience is mainly with the 5 kVA and higher rated models.
On 2025/04/08 at 4:02 PM, Ezzedeen said:
Hello guys,
Hi @Ezzedeen this is only possible for 48V models, with some modifications to the mainboard.
Best Regards
