MUST 3.6KW - Model PV18-3624 ECO
Good morning!
I have just purchased the above inverter for basic backup power.
A little bit of backround.... Based in Botswana. We have suddenly been getting load shedding because of issues with our only power station
that was built by the wrong people! Africa....
I will be runnning 2 x 100AH Camel Lead Acid Batteries in series to start as I have 2 fresh units that were meant for another project.
All I want to run initially is the TV, Router, Charge phones and couple of lights.
Next I will probably starting buying 2-3 solar panels a mcnth. Once I have 8 , I want to wire everything into the DB board.
Lastly, I will get a lithium battery. On the whole we dont get many cuts and government is moving fast to sort out the issue but for piece of mind
I need to have backup for basics as well as alarm and cctv.
From what I read in the manual , a lot of the presets seem fine for my current setup.
My main concern is not running the batteries over 50% DOD. This falls under option 19 (low DC cut off battery voltage).
Is 24.2V safe?
Secondly, I see mention of an equaliser mode/dept. Would you still recommend running a battery balancer with this setup?
If anybody recommends any other changes to the default settings I would be really thankful !!
Edited by Mickeyblue42
typo
6 hours ago, Mickeyblue42 said:
Good morning!
Is 24.2V safe?
Yes you still want to use the battery balancer to keep both your batteries at about the same voltage level.
