April 12, 20251 yr I have an Easton meter sending signal to inverter via cat 6 cable. The inverter is about 25 m away from main grid supply.I have followed the instructions to the book and cannot get the inverter to use the energy readings from the meter. The ct reading look fine on the inverter.
April 15, 20251 yr Did you follow the settings in this guide setting all the eastron settings.https://support.sunsynk.com/support/solutions/articles/103000283273-3-phase-eastron-meter-with-3-phase-inverterIt worked for mine
